Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I finally isolated the annoying rattle I hear every time I go over a bump. It seems as though my rear side elongated large window is a bit loose. How do I go about tightening it??
I had the same issue on my wife's yukon. I found that the little plastic piece was rattling against the window so I put a strip of foam tape in between the two pieces & it solved the problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
