Rear Suspensions & Air Compress.. 2016 Yukon SLT XL PLZ Help!
M
maidi3000
In my 2011 Yukon XL I had Magnaride air leveling shocks in the rear. Regular Magnarides up front. As for handling and ride I added a heavy sway bar in front and back. Those sway bars did not affect the straight line ride, only the handling around in turns and corners. You will be disappointed in Bilsteins if you value ride.
Would you plz tell me and the others here, if you have the part#, of those heay sway bars and from where you got them..
I couldn't understand " you will....you value ride" I do not understad US accent or local speech..I know little En..sorry :angels2: :Big Laugh:
M
maidi3000
I just saw Hellwig Bars somewere here..I will read about them..o_Oo_Oo_Oo_Oo_O
M
maidi3000
:eek::eek::eek::eek::oops::oops::oops::oops:
Hellwig front and rear sway bars without shipping almost $ 1000 !!!! Toooo much!!
M
maidi3000
Update!!!
2 days ago, I removed the air compress (without taking out the Neg battery) and took out the harness (cut the red & black wires and covered with electric tape), the grey and blue wires, I think from the exhaust valve, put the resistor 3.9 ohm between them, the sensor removed from AC and plugged to harmpness and covered well.
Fitted the harness back and hanged somewhere under the rear bumper..
No error codes appeared in tha dashboard since.
Today i will remove the old rear air ride suspension and put B 4600 and check the ride..
fishslayer
