when mirror is working properly the dimming mode is changed when you select reverse gear.
Aha ok I will try it out to do an external wiring to the miror this way: (modes)
1- power OFF (day time)
2- power ON (when lights are rurned ON too)
What do you think?
1- I will supply it from the battery or I have the fuse board neer the door (un used powered fuse socket)
2- I will get the signal from lights fuse too.
Could you please help if you have a diagram showing the mirror socket and how to feed it?
By the way I found something strang to me a number of relays and wires under or actually front off my left foot (driver side) what is this??
---------- Post added at 03:59 PM ---------- Previous post was at 02:57 PM ----------
Ok I am assuming here:
If I feed the miror using two wires (+ -) only!
1- The compass will work
2- The small green screen will work
3- The temp wont work (I dont have the extirior sensior)
4- The dimming wil work all time.
By the way I just got an idea, if I am uncomfortable by the auto dimming (or dimming in genral) how to shut it OFF completely?
I am thinking my be this what happened by the previous owner.. hmm
