rear wiper fluid leaking.
nj2012
I found the rear wiper fluid pipe leaking from the bottom of the rear driver side of the car. When I went down there to check it out. the hose basically disconnected from whatever it was attached to. I can't find where the hose connects to.
Where does that tube connects to?
Parthery
Atlanta, GA
The other end of the line is behind the bumper...you should see it hanging there.
There is another "Blow off" fitting under the hood...they are set up that way by design. If the fluid freezes, it pops off and releases the pressure.
Snap them back together and you are on your way.
patniven
