Rear Wiper Washer Not Working
OR VietVet
Multnomah Falls
Military
Willamette Valley
There is a clog there somewhere or the pump is not pushing enough pressure. The water at the hose just before it get to the wiper arm should be a good solid stream. When you used a pin you may have just pushed the clog deeper in there. Find and use compressed air to blow that all out.
byrds6
FL
I don't own a compressor. That's why I used canned air. I wish I could get to where the hose connected to the spout on the arm but can't. If I could I'd try to blow it backwards from there too. It's been a real pain tracking this. Had my son watch the back when I pressed the sprayer today and it sprays out from the hatch pretty good so I don't think it's the motor.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Sounds like the water getting there is no problem so the arm needs to come off and take to a shop where the rest of the path is blown out. Are you saying where the hose attaches near the arm is hard to get to?
byrds6
FL
Yeah the part that attaches in the blade itself. If I knew how to pull the hole arm off Id do it myself lol.
KDM72
I have a 2011 yukon wand my rear washer not working. I pulled the line on the back and nothing comes out. I can hear the pump running but no fluid. I have looked under the truck and no fluid any where. Can the pump be bad if I can hear it running? Thank you
Danny3737
It sure can. You either have some debris at the pump or a broken shaft in the motor
bruh2125
