rebuilding G80
rxphiler
Charleston, SC
Hey guys my carrier gears are shot in my rear end I am trying to locate just the carrier gears. Has anyone done this before? I have the G80 with 3.73 gears.
thanks
96ProCompTahoe
IN
you might as well replace the G80 with something more reliable, several much better units out there to choose from.
if you had been about a week earlier i had one for sale i let go hella cheap.
crmzendrgone
M town Arizona
EATON TRUETRAC!!!! FTW!!!!
Thats what happen to me, well the ring and pinion. Pinion decided to grenade took out 8 teeth on the ring while doing so.
Definitely new, if not try junk yard. I dont think you can get just the gears. To bad you live on the other side I would give you my carrier. still good
rxphiler
rxphiler
Charleston, SC
I have a guy that has a 14 bolt 3.73 9.5 in 6 lug rear end for sale out of a 97 P/U but I dont know if it will fit? what do you guys thinks. and thanks for the help!
rxphiler
rxphiler
Charleston, SC
thanks!!! atleast I know they are availble. I am going to look at the 14 bolt tommorrow to see if it has the same measurements.
steamroller
The South
Bolt in swap for the most part, but you'll need a conversion u-joint, Precision 447 IIRC.
Make sure it's a 4wd rear or you'll need wheel spacers because they came in 2wd trucks that were 6 lug
bowtiefreak
No Quarter
Near Philly
trutrac...take the G80 and toss it.
14 bolt is basically a bolt in coversion...new U joint and new U bolts
nimrodcs
Joplin, Missouri
I've got one just like it. It was out of a '95 though and is a G80 (grumble). Almost have it ready to install. Looks like everything is a direct fit, so we'll see. Make sure you get the bottom U-bolt plates if you get the axle, its a larger dia. than the 10-bolt. If you can get it at a good price, I'd go for it. Just the difference in size is impressive.
Oh yeah, the coversion U-joint I got is a Precision #447 at Summit. $46 delivered.
TruTrac FTW! Can't wait till I get mine. :)
WashFarm
