rebuilding my TBI.. tips?
Indiana
I own a 93 hoe w a TBI 350 in it... having fuel delivery problems so im rebuilding the throttle body. any tips before i start? i only have a cheap BWD kit because thats all that was readily available to me. the P/N is 12130 i do believe. if anyone has helpful advice, i would appreciate it. if yall want pics let me know and ill post some. i also got some TB cleaner to scrub everything off with. is that okay to do?
retorq
Kingman AZ
Yeah get more tb/carb cleaner like 3 cans and hose that thing down. Take your time and triple check everything going back together and you should be fine. I would do the free TBI mods from thirdgen.org while you are there.
T
Indiana
i hosed it down like crazy, went thru two cans almost. but is looking a lot cleaner now. is there any specific way that i should have cleaned the Fuel pressure regulator? i just kinda disassembled it and cleaned it really well then put it back together lol
retorq
Kingman AZ
Unless you were changing the spring to make it higher pressure or converting to adjustable, no.
T
Indiana
read thru my other post...
http://tahoeyukonforum.com/forum/showthread.php?t=40769&page=3
the reason i cleaned my throttle body is bc when my motor runs really rough my injectors start dumping fuel so i figured maybe my fuel pressure regulator was bad
---------- Post added at 09:52 PM ---------- Previous post was at 09:51 PM ----------
sorry that link is for the end of the thread. please read thru it all if ya can lol
N8daGr8
