Recommendation on replacing oem shocks. Kyb, bilstein, belltech ????
adam p
Tampa
Searched, didnt find my answer... Looking to replace the current oem units. i do a lot of highway driving with a couple hundred pounds of stuff for work. truck is leveled in the rear with springs and on 24s with 35 series tires. heres my current choices
Kyb excel-g:
http://www.ebay.com/itm/KYB-Excel-G...Parts_Accessories&hash=item51a1b8731f&vxp=mtr
Or billstein gas:
http://www.ebay.com/itm/BILSTEIN-He...Parts_Accessories&hash=item589c670d5f&vxp=mtr
Or belltech street performance;
http://www.ebay.com/itm/Belltech-St...Parts_Accessories&hash=item460ea74b38&vxp=mtr
They are all roughly $300 for the set, didn't know if one was far superior or vice versa. Also just replaced all fluids, belts, plugs, ball joints, etc at 100k. trying o do all preventive maintanence before needed. what else is coming up?Thanks guys
jplong
Cincinnati
Adam...from what i have read I have seen that Bilsteins are the best route.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
unless you get the new valving that im working on getting set up on the belltechs :)
adam p
adam p
Tampa
Ya that's what everyone says, either belltech or bilsteins. If the belltech guy says the bilsteins > current belltechs, I'll have to go with them
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i think its on the person driving. Ive installed both. Some people like bilsteins while others i swapped to belltechs for a smoother ride. Id say get the bilsteins from a place you can test them out and if you dont like em just return them
adam p
adam p
Tampa
I do a lot of highway driving with a lot of weight in the truck. A less bumpy ride would be awesome
adam p
adam p
Tampa
Just ordered the bilsteins, will update once installed
jeffm
what shocks to use
Hi -- I'm looking for similar information, but for a different driving scenario. I recently bought an 07 Tahoe, 87K miles, original shocks. I pull a 4K lb trailer for work and the ride is a bit bouncy. I previously had a n 05 Tahoe w/ the air suspension and had no bounce problem. Do you think changing the shocks to more heavy duty ones will resolve the bounce, or do you think I should change the springs, or both? And if shocks, Bilstein? Are there different models of Bilstein? If so, which one should I get? Thanks!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
jeff airlift helper bags 80 dollars and they will work perfect. pm me ill shoot you info i just did one on monday same issue you have and hes towing his car out to the street races tonight with me and ill keep you updated.
johnk71
