jlatenight
- Joined
- Feb 25, 2011
- Posts
- 25
- Reaction score
- 0
I have an '08 Tahoe w/ ~180k Miles. I've been having recurring issues with my Oxygen sensors on both sides, downstream (after the Cat). More often with the passenger side (Banks 2 sensor 2), which I have replaced, and I have taken it out a few times since and cleaned it with carb cleaner when my check engine light comes on (P2272 - O2 Sensor Signal Biased/Stuck Lean). The same code eventually comes back at some point. Last time I cleaned it was probably a month or two ago.
Now the driver side is throwing the same type of code (P2270). Same position, sensor 2 (after the Cat). So both sides are currently throwing a code. Are the sensors going bad, or is it an indication there's a bigger problem with the exhaust system? When I take the sensor out, it's pretty sooty, and if I stick my finger in the hole there seems to be some residue build-up on the inside...seems dirty and kinda moist, but it's an exhaust system and maybe that's normal for its age?
I notice I do have to top-off my oil once inbetween oil changes. Since I'm not leaking oil on my driveway does that mean I'm burining oil and that's why the sensors are getting fouled? Maybe my Cat is causing the problem? Motor sounds great, and no other issues.
Would you just deal with it and keep cleaning the sensors and then replacing them when they start throwing codes more often? Anyone else have this issue? Thanks guys!
