tell them it's a ECM and or BCM Computer module issue they can fix it other wise they need to close shop..... that means they can't work on any other car as they all use the similar computer...Thanks for the information on the dealer in Oaxaca. Unfortunately we had the car there for two weeks, since it was right outside of Oaxaca that the car quit working. The service manager there told us that he had never seen a hybrid and that they couldn't fix it. I think that it's true that he had never seen a hybrid, but I don't think that he tried hard to figure it out, that he didn't want to mess with it. Sad but true.
check the battery cables mine was pretty dirty under the ringsAgain, thanks for all your replies! IT's taken a while because we replaced a the oil pressure sensor, and found that the timing chain tensor was broken, and so replaced it and the timing chain. We also bought a new battery. Afterward the car ran great for about rwn minutes, and like before the codes started screaming in and the power was reduced until finally it shot off. Now it won't turn over or crank. So there's a new set of codes from my scanner, which was given to me by a mechanic friend when he upgraded a few years ago. They are P0C17, P0C18, P16F9, P0AC4, U1815, U1817, U1818, and U1820. We looked over the PCM and ground wires, but didn't see anything obvious. There's a Chevrolet dealership about 40 minutes away from us, but they've never seen a hybrid here. Any suggestions on what to do next?
Glad it was a simple fix sometimes it's the basic things that cause major issues hybrids are particularly sensitive to 12V battery issues.You all are lifesavers! So with a new battery, cleaning the cables, both the battery and especially the ground cable on the firewall, it fired up and is running like new again! Finally...
