Refinish headliner?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Those dumb coat hooks in the back lol Also the black plastic piece under the visor. I figured out what it was for, it's a washer, there's a screw in there that holds the headliner up on the driver side.
Also note, you don't necessarily have to remove the wiring harness. But it does need glued back onto the top of the headliner when you put it back in. It's a SOB to unplug, you have to disassmble much of the dash to do so.
I just removed a headliner at the junk yard (and reinstalled it, I'm nice). It took me all over about 15 minutes. I pulled the sun roof as mine has too many issues to repair.
Also I figured out, the foam sandwiched in-between the fabric and the headliner is the headliner. There's a thin film of fiberglass between it and the fabric. I didn't see that until closer inspection.
Hopefully I can finish all this work up. My next item on the list is a 6.0L and 4L65E swap :) - I have that in a separate post.
Sam Harris
Texas
Not to mention, the foam is what breaks down and makes to original headline fall off and sag.
If you don't remove all of the old foam the new fabric will soon start sagging again.
I always got foam-backed fabric to do my headliners. If yours isn't, I imagine you're going to have to add that layer yourself.
I assumed the replacement fabric will be foam backed. And there’s another layer below that, attached to the headliner, no?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
there is. i have to order the fabric yet. butnit comes with foam backing. i confused the foam structure of headliner with the fabric.
Sent from my SM-A505U using Tapatalk
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
hit a new snag. i got a ndifferent sunroof assembly from salvage yard. its all cleaned up and in the truck. however the motor is toast. gears are cracked in it. i need to find new gears or a new motor. however gm discontinued the part number :(
Sam Harris
Texas
Do not like
mountie
RE: Headliner fabric color
I had a (sort of) custom molded dash cover ordered.... About 5 months ago.
What I wanted to caution you about is the "sample card / sample swatch"......
The sample was not the same color batch as the actual material they had in stock.
Have them send you a slice of the ACTUAL material they believe is your color.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
that would be very frustrating. I ordered samples from nelson's auto supply. frustrated as I have not seen them and want to finish the project. I may just order the closest color that stock interiors has and say the heck with searching for a closer match.
I ran into something new. I need to figure out where to order these clips. they are missing from my driver side and think maybe reason for intermittent rattle I have up there.
wjburken
Eastern Iowa
that would be very frustrating. I ordered samples from nelson's auto supply. frustrated as I have not seen them and want to finish the project. I just order the closest color that stock interiors had.
This place might have what your looking for.
https://www.clipsandfasteners.com/G...minprice=11&maxprice=&brand=ClipsAndFasteners
Racerzl1
