Relocate Gas Tank
Monstar_est87
City of Angeles
U'll have 2 remove ur spare tire gear underneath in the rear and ull need longer fuel lines, reroute or fab up a fuel neck, and extend the electrical wires for the fuel pump... And then ull have 2 mount some custom fuel tank strap retainers to hold it in place... Not impossible, but its only like a 12 or 15 gallon tank... If ur looking to reduce weight and balance out.ur ride this would be the way 2 go...
O
OrangeTahoeSS
San Francisco, CA
Perfect, Thanks Man! :D & Yes, That's Exactly What I Want To Do. Also Build A Nice Dual Exhaust! :thumbup:
Sent from my GT-P5113 using Tapatalk 2
Gzes
the drifting 2dr
Wichita tx
Jist remember that the guard for the tank in the 2dr is heavy and sucks to remove or intsall.. yoy also have to relocate the filler to the back. Why not run dual tanks like a truck? Have a switch to change pumps
O
OrangeTahoeSS
San Francisco, CA
A Friend If Mine Owns A Fabrication Shop, Could Probably Make Our Own Cover.... Relocate The Fuel Filter?? Does It Have To Be A Certain Distance.. If I Were Not Building It As A Performance Truck That Would Be A Great Idea. But To Much Weight.
Monstar_est87
City of Angeles
Not sure if its all burbs or sum... But I have seen a few with a rear tank... Not sure if they have both... Might b worth looking into...
20DENALI07
