Remote Starter Luck/Unlock
_Spanish_
So installing a Viper 2 way remote starter 4806V but can't seem to find where I can get to the door lock/unlock under the steering wheel somewhere, im sure I can add wire to it and route both cables towards the buttons on the door I guess but if I don't have to or I could get a wiring diagram for out trucks it would help a bunch. 2004 gmc yukon SLT.
Blackie
SoCal
DIRECTWIRE™ WIRING INFORMATION - GMC / YUKON / 2004 / Remote Start
12volts red & red/white + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Power Lock use Directed module 456G
Notes: If Directed module 456G is not available, refer to DirectFax document 1601. Upper trim level vehicles may have a door lock switch on the right rear panel. If present use white (-) for lock and lt. blue (-) for unlock.
Power Unlock see power lock
Lock Motor gray driver door module in door
Unlock Motor tan driver door module in door
Parking Lights+ brown + driver kick panel
Parking Lights- gray/black - switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white - steering column
Turn Signal(L) green + steering column
Turn Signal(R) lt. green + steering column
Reverse Light lt. green + BCM, black plug, pin F
Door Trigger see notes - see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is black/white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. green/black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black + BCM, black plug, pin E
Trunk/Hatch Pin pink/black - BCM, purple plug, pin A1
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white + brake pedal switch
Parking Brake lt. blue - switch or BCM, lt. blu plug, pin A7
Horn Trigger black/yellow to black - column or BCM, gray plug, pin B9
Memory Seat 1 red + driver door module in door
Memory Seat 2 pink + driver door module in door
Memory Seat 3 N/A +
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and red/white (not used).
_Spanish_
_Spanish_
Thank you so much, couldn't ask for a bet answer.
Second Starter N/A
Third Ignition N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 3 N/A +
Second Starter N/A
Third Ignition N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 3 N/A +
YukonandtheHOE
OK, well I haven't heard anything about a bypass
They all need a bypass for security defeat. Now days you just hook Remote start to bypass, hook by pass to bcm and bingo bango, you have Remote Start with all the functions via serial data, no fuss no muss
_Spanish_
_Spanish_
OH ill give that a try! I'll start researching to pick one up tomorrow then thanks! So much
_Spanish_
_Spanish_
Any preference brand to buy for the bypass? Have searched and seen that pass lock is popular however I would like the so called full featured one with auto heated seats and defroster. If possible ofcorse
derek1387
I just used a Compustar Blade-AL unit this morning on mine....super easy to use/program
stking
