RENAMED!! The adventures of Chase and his 2006 Yukon XL Denali!! Follow along on my travels!
05Single
afraid of the dark
W8TVI
Traverse City, MI
@W8TVI , gotta pic of said harness under the rear bumper? I'm so confused. I'm fairly certain the only kind of wiring harness anywhere near my rear bumper is the trailer light hookup on my tow package.
No, I do not. The LED tails I put on my truck hooked into the light bulb plugs, but @chevrol8t said in his post that the "harness connection was underneath slightly past the bumper."
(It is also too cold out right now to go out and lay on the ground to take a picture)
adventurenali92
adventurenali92
Big Bear Lake, ca
Yeah I read through the post and it was pretty confusing. I did a Google image search and found a picture of a light swap on a 2000 suburban showing that under body harness. I will look in the morning to see if my truck has that harness. In the meantime, my led tails don't even have a harness that will reach down and plug in. So whether my truck has that harness underneath or not, my led tails won't work. They aren't compatible. I will have to return them and wait for a refund, and then order the ones that he has with a harness that reaches down. Damn.... this really sucks..... stuff just can't ever be simple. ..:mad::Angry:
W8TVI
Traverse City, MI
For what it's worth, I did find this on the GM parts website:
And it shows the same parts for a 2006 truck, as well.
adventurenali92
adventurenali92
Big Bear Lake, ca
Yeah that's just a stock tail. But I can see the Grey harness that goes down under the truck. The tails the other guy has, has that exact harness to run down and mine don't. So I don't think my leds will work unless they get completely rewired. Which I'm not capable of. So for the time being I've messaged the seller to try and get the return started so I can get a refund on them.
adventurenali92
adventurenali92
Big Bear Lake, ca
Seller that sold me my tails is a distributor and they have the warehouse tech trying to figure out why the left turn signal doesn't flash the same as the right. They want to send me some resistors to attach to the brake sockets to try and fix cruise issue. Will see what happens with it. In the mean time I finally got my mechanic buddy to drill out a small section of my headlight brackets to allow my vouke G8s to go into my highbeams and clear the bracket. Used them last night and the leds are killer.
05Single
afraid of the dark
That lettering was showing its age. Glad it finally came off. Lookin smooth and silky!
ccy333
