Replace light bulbs with LEDs!?
Tonyv__
Bucks county PA
I use these on majority on my gm trucks. Never any problems. $10 a set and they’re bright as hell... however my newest truck is a 15. It doesn’t notify me if a reverse bulb is out so idk how it will cooperate with the 21s
License plate lights shine nicely too 318CCE3F-8B2E-48EE-8E85-7B68EA15BE8A.png
Nav792
Orlando, FL
I have a 2021 Premier, same rear assembly, amd was only able to find the amber turn signals that work without receiving an error. The reverse and Brake lights give an error on startup ( I have tried over 10 pair of canbus bulbs). As far as the turn signals, the bulbs are 7440 and the ones attached work excellent on my 2021 Tahoe Premier 4X4 with zero errors. I hope this helpsView attachment 271349
These worked for me as well with no errors. Just need an error free plug and play replacement for reverse lights now. thank you for sharing!
Nav792
Orlando, FL
Your gonna need resistors for the reverse light. I order vled resistor for $15. You only need to put it on the left side. Just about any Led bulb will work with it. I ordered auxito for $20 from Amazon. All good now
Bigmanny
Guy in this post said that lasfit has something that works for the reverse lights.
Kevz1088
Tried the diode dynamic 921xpr’s and they also gave the check reverse bulb message. Too bad, because they were super bright and looked great. The company said I needed resistors, but I decided just to return the bulbs instead.
JR09country
Edited - Oxilams from Amazon do not work.
Sent from my ONEPLUS A6013 using Tapatalk
steveatwell
