Replace the stock sub?
Lindgren
I want to either replace my stock sub, or give the existing one a boost in power by replacing the amp.
I have no Idea what setup is in there. Any low cost suggestions would be great.
2002 Yukon.
Thanks
blueflamed03
Oklahoma
for cheap, start off just replacing the sub to a better one. OEM one's 'usually' aren't up to aftermarket standards. Some newer cars DO have great systems.
But replace the sub. If still dis-satisfied, then you can always add an amp.
Be sure to watch depth of sub you put in, and match impedance.
L
Lindgren
Do you know what size is in there now? Can you recommend a sub? And do you happen to know the impedance off hand; so I dont have to take it out and look...
Thanks
txsmainevent
"The Lurker"
Texas
I pulled mine out yesterday while replacing the door speakers. I disconnected mine. On the Tahoe's its a 8'' not sure bout the Yukon. Simple to pull out....
L
Lindgren
I think it is the same as the Tahoe, 8". And I googled the impedance 4 OHMS... What would you recommend for a cheap upgrade?
01yukonslt
need more deebeeeez!
Spokane, WA
I built a little ported box for mine and it boosted output quite a bit honestly i was surprised. i had left over wood from my box i built for my Fi sub im ordering and some spare time so i threw together a box thats about .65 ft^3 and 40hz was the lowest i could really get the tuning down to but it worked out pretty well. i can get a pic when my phone is done charging.
---------- Post added at 01:11 PM ---------- Previous post was at 01:10 PM ----------
and idk bout the difference from 01/02 but i just had my sub out 3 days ago and it said right on it 2ohm
07Denali
If it is a 2 ohm then a dual 4 ohm sub should work fine. Just run both positives and both negatives together to the two leads from the amp.
Or find a 2 ohm svc sub. The slim mount is going to be the trick if necessary, probably going to need to be a RF or a Kicker.
Dieseldr
