Replaced belt tensioner on 2002 5.3, squeal got worse SOLVED
JohnnyRosso
Hello. So, I have a 2002 Tahoe with a 5.3L V8 (241K miles) and I've been having some rough idle issues/ intermittent belt squeals for the last 50,000 miles or so. I've done a handful of things to calm the idle down, and I just replaced the belt tensioner pulley yesterday (the bearing was bad) in hopes my squeal would go away. When idling, the squeal is gone now. Oddly, whenever I hit the throttle now, the squeal is really bad (much higher pitched and louder than before) and sounds like it might burst. Not sure if I tightened the belt incorrectly and its too tight (or maybe too loose?)... Anyone have something like this happen before? I just want the belt to ride smoother. I'm going to try tightening and loosening it when I get a chance, but any advice is much appreciated. Thanks!
MassHoe04
Western MA
Tensioners are spring loaded and apply the appropriate amount of tension on the belt automatically. If the belt is the correct size and not all glazed over, it must be another pulley seizing and causing the belt to squeal.
Take the belt off. Inspect for glazing.
If OK, look at the fan clutch and other pulleys to make sure they move the way they should.
^^ THIS. Also, do you know that it's not the A/C belt that's making the noise? Try removing that belt to help diagnose.
If you replaced just the tensioner pulley, do you know if the tensioner spring is good? Is the belt the correct one for the alternator size?
EDIT: tell us what mfr and part numbers you're using for the tensioner and the belt.
Looking from the top of your engine compartment, does your tensioner have marks (like below) and where do they land? Post up a pic of yours.
MassHoe04
Western MA
I'm still new to GM and the 5.3 and haven't taken a deep dive into the front end of the engine bay... I'm not used to seeing a completely separate belt just for A/C.
Good call on checking the belt, tensioner and A/C compressor pulley and clutch for noise!
J
JohnnyRosso
Ok, so I just checked out some of the other pulleys a little better and checked out everything you guys suggested. I don't have an AC belt.
1) The alignment on my tensioner is pictured- it is definitely off compared to you guys'. However, I can't adjust it any more without it loosening- could this be an internal spring or necessary tensioner replacement?
2) Also, I realized that another pulley is slightly loose and I want to replace it. I'm not sure what this one is called, but it is the bottom right pulley (I included a picture of my belt diagram). Do you guys know what that one is called?
3) I also am going to replace my idler pulley because the belt rides kind of on its edge for some reason, and I'm going to throw on a new belt even though mine isn't really glazed (as far as I can tell atleast) just for good measure.
4) I have a video of the current status but I'm not sure if the site will let me post it here. Have you guys uploaded a video before?
To post a video it needs to be hosted somewhere (like YouTube), then add the link in your message here.
The lower righthand pulley should be your power steering pump. And that tensioner looks like it's shot unless the belt is too long. What part number is your belt, and what alternator do you have (105A or 130A, maybe)? It should be stamped into the alternator body.
MassHoe04
Western MA
Was the belt off one track on one of the grooved pulleys?
I had a misaligned belt once, when I had taken it off and put it back on for the fifth time on my wife's Hyundai. When winding the belt through, I did not get the belt onto one of the grooved pulleys completely. I was surprised it wasn't thrown off and shredded when I started the engine. Somehow, it managed to hang on until I noticed what was going on.
J
JohnnyRosso
Ok, so as far as I know I have a 130A alternator. I’m not sure what belt I have, but I’m going to get a new one and I will make sure it’s the right length for the 130a. I am pretty sure that my belt is the right size because it worked fine for the last several years until I started replacing things this last weekend. Either way though, I’m going to try and replace it with the idler pulley and the power steering pulley
J
JohnnyRosso
Interesting! So, my belt isn’t off on any of the grooved pulleys, but it is off on the smooth idler pulley (which is so odd)- I wonder if it’s just slipping there?
MassHoe04
Western MA
Grooved pulleys guide where the belt sits along the rest of the way. Kind of like a train on tracks. It goes where the tracks go. The fact that it looks odd on the idler pulley has me stumped. Is it the correct idler?
