Replaced steering idler arm, now steering wheel noise
D
diezelraccoon
Some years back there was a TSB on the Silverados about a plastic sleeve in the steering column in the dash that was making various noises, pretty common seems like. Might search around for this deal. What year is your machine?
2003
tom3
I am thinking the Column Bearing. Have you checked it?
Look under the dash, and find the steering-shaft. Now grab a hold of it and push back and forth "Up/down". If there is any movement then that could be where the noise is coming from.
D
diezelraccoon
I think it might be from that. The bearing I suspected was bad because of knocking sound. I did check and you can grab the shaft and push up and down and there’s play/knock to it. Attached is a video under it and I think that stretching straining spring like sound is coming from that bearing. I’m unsure how replacing the steering idler arm lead to this sound.
elianymanol
