Retro chip installed
prettySUV01
Arizona
Finally got the chip installed for the front/rear park asssist on my '22 Denali. I can see what it added for front assist, but don't know what was the improvement for the rear assist. Could someone tell me. TIA
Tahoe14
Central Fl
Does the owners manual give a description of the function of the rear assist.
CMoore711
Prior to the chip install…
Did your backup camera function normally and as it should?
Did the guide lines appear on the screen when your back up camera was activated?
Would your vehicle beep and sound alert as you got closer to an object while reversing? If so, would the sound become louder/faster or different as you got closer to said object?
If you answered “No” to any of the above questions and then after the chip install the answer is now “Yes”…
dcyy
What it added in for rear assist is exactly the same as front assist with warning display in DIC and alarms
ZKWBQD
I hated having that chip. I couldn't wait to remove it. I can't stand all the beeping. The camera is good for me.
nicklife
