Retrofit console subwoofer box?
Wow thanks for the heads up. What other powered sub is less than 10” wide?
I don’t know of any of those powered subs in those small enclosures that sound good unfortunately. I wish Rodneys Boxes made an enclosure for the NBS like he makes for the NNBS. I put one of his in my 08 Silverado and it hits hard with a 10” down firing JL. It utilizes all available space without interfering with anything. Maybe you can build something.
8B4D2D11-02AD-4041-AF60-E8CD08D2D9C8.jpeg E84397A7-BA4F-4093-A977-94CB1036B3B8.jpeg 5DA39CE1-5534-462D-9D07-F5DC91134DE5.jpeg 1DA03056-FB5B-498C-BBD2-46FE920C6388.jpeg
Rayyy
Rayyy
Northern California
I wonder if the one @Fosscore added to his nbs would work for you? He has a build thread. You can also check it out in the classifieds, as he's selling his Tahoe, but he has all his mods listed.
EDIT--Look in here:
https://www.tahoeyukonforum.com/threads/fosscores-2006-chevrolet-tahoe-ls-4-8l-2wd-for-sale.119198/
Wow Fosscore’a Tahoe is impressive. I see the build specs state that he has a Stealthbox in the console, but I can’t find any posts that show it.
Rayyy
Rayyy
Northern California
Rayyy
Rayyy
Northern California
There is indeed a lot of space under the center console, especially if one were to remove the storage compartment and build a more shallow one to be able to use the space below it.
On the other hand, perhaps more of a less punchy mid-bass in the console may not be that bad, given that a strong woofer would rattle everything in the cup holder and console compartment.
Plus, building a box would also require a separate woofer and amp, further increasing the cost.
Dilemma continues. I guess I’ll do some research and cost analysis.
Rayyy
Rayyy
Northern California
I’m telling you, the powered one will leave you unsatisfied especially if you already have a rear sub. You won’t even know it’s there and that money could be put toward a decent setup.
Edit: when the sub fires down you don’t really get much console rattling.
kses123
kses123
Raleigh, NC
Pretty sure it won't fit into an 01 console. Again, I think the console is not wide enough. I could be wrong.
Rayyy
Rayyy
Northern California
Hmmm okay, good point.
JFrisko
