ride height after djm 3/5
Bikeboy80
Pa
Same thing here... Driver side is cranked all the way in, passenger side is out 5/8" to get the truck to sit level at 32 5/8"
JayXSP
Wallingford, CT
Keys/Spindles/H3 Shocks up front
4230/reloc kit/bilstein shocks/shock extenders/free travel mod rear
thats why your lower...spindles and keys allows for more drop than just arms...
im installing 3/4 ton keys (cranked) over the weekend to get the front down a bit more. Only way....
Alex33
I'm thinking of going spindles/arms up front so I'm curious to see how the arms and keys ride.
candyman74
candyman74
arnold, mo
so after the alignment, driving, and adjusting the torsion bars some more i have got the truck sitting as follows
drivers front 32.5
pass front 33
drivers rear 32.75
pass front 32.75
i know its only half and inch difference in front but its still driving me crazy is there anything else i can do to get that pass front lower?
JayXSP
Wallingford, CT
I'm in the same boat man...the only option I see is to install 3/4 ton keys and crank em up so that way your not slammed. If anyone else has another option I'm all ears.
My measurements as of now are
Front driver - 31.5"
Front pass - 32"
Rear driver - 32."
Rear pass - 32"
I'm running an inch shorter tire but the overall issue is the same
Max
Mile High
Denver
One of my adjuster bolts is cranked all the way and my other side is about 1/2 way cranked. There are some serious variances with torsion bars, hence GM's approach to resolving these issues by allowing so much adjustment with the bolts in the tbar crossmember.
OklahomaSideShow
