Derick
Again all my front suspension is brand new. UBJs, LBJs, control arms, sway bar links, sway bar bushings, hub bearing assemblies, and my tires are milestar patagonias 245/75/16 which is factory spec.
What is the load range for these tires?Again all my front suspension is brand new. UBJs, LBJs, control arms, sway bar links, sway bar bushings, hub bearing assemblies, and my tires are milestar patagonias 245/75/16 which is factory spec.
just my 02, but 50/70 psi will transmit every road imperfection like a seismograph recording a 7.1 quake. those pressures are for supporting the gvw of your vehicle. Just for kicks run 35 on all four corners and report back. also if your front diff is a metal slurry than wtf do you think is going on in there? No disrespect whatsoever is intended! It is kinda comical to wonder if the front diff coming apart could affect vibration? especially when you drive on roads with high tire pressures, those tires transmit the shock to the loose unsupported internals of the diff and they sing like a tuning fork. when it does come apart it should be a memorable experience, Im in!
