Rob's NBS Build
PR RAY
@blurred Hey when you took off the side steps (Neff bars) i also noticed you removed the plastic rocker molding did it leave holes in your Fender Flares? and was it hard to remove the side steps mounting bracket? Thanks
thanks @05Single
RobbieX210X
RobbieX210X
Don't Hate! V Eight!
New Jersey
The Tow\Haul mode button hasn't worked in years. All of a sudden it started to go on by itself so you would have to tilt the steering column or shift from park to drive a few times to turn it off. I found that the wire has been severed from the shift stick so that might explain the button not working. I figured the other half of the wire was touching something to trigger Tow/Haul mode.
I decided to trace the wire and to my surprise I found the connection fairly easy and decided to just unplug it. You can see the wire sticking from the shift stick so I believe I unplugged the right wire. I don't tow with this truck so I don't need to spend any money to fix it. I found some small write ups on fixing this so maybe in the future I will fix this. :hands:
This took a total of 5 minutes.
Chadricckglenn
