Mondo
- Joined
- Jul 26, 2015
- Posts
- 133
- Reaction score
- 16
I recently aquired a white 50" curved light bar and 2 Led pods for reverse.
I wanted nice looking illuminated rocker switches I went with Mictunning switches from amazon.
and I wanted a real nice clean looking install.
I bought 1 square feet of ABS plastic from amazon.
And youll need the mounting housings for the switches it makes it a whole lot easier also sold by Mictunning on amazon.
So first I removed the Onstar buttons some of you may have a cubby there just remove that also so that you can run the wires threw the opening.
I cut the square out of the ABS plastic to size to cover the opening on the Dash trim piece not the dash it self and then I cut out the hole for the switch housing. Then I hot glued the plastic to the dash trim piece I did it this way cause there wasnt an easy way to mount a flat plastic to the dash itself.
FINISHED PRODUCT.
TOP AND BOTTOM ILLUMINATED WHEN SWITCHES TURNED ON
ONLY BOTTOM HALF OF SWITCH ILLUMINATED CONSTANTLY
FINISHED PRODUCT.
