I’ve been doing some work on my door panels and painting the exterior door handles that were worn and had white plastic showing through. I painted the speaker grills with the same color paint that the console is done in, kind of a dark pewter I think it is. Not too much of a change but I like it, a bit of contrast.
E653644F-F0A3-406C-9F6C-A803EA93D3D2.jpeg 330C5BF6-4459-4F79-9FCD-6EE23A8706D0.jpeg 045D288D-D56F-4F29-B9B4-9F3AB5EA3F51.jpeg
The door handles were going good until they weren’t. I got the rear doors completed this morning after the paint on the handles dried overnight. They came out perfect. I had most of a can of Automotive Touchup left over from an other project and half a can of U Pol #1 clear, plenty to do the fronts too so today I pulled everything apart. I disassembled and scuffed/sanded the handles, painted them and cleared them. I thought I did a perfect job until I noticed one of the parts, the driver escutcheon or whatever it’s called, had a spot in the clear that was messed up. I tried to respray it but noooo. So I removed all the clear, re-scuffed, painted and cleared again. Then as I was spraying a second coat of clear I saw I messed up
and left some clear on the top edge. I then removed all the clear AGAIN, re-scuffed and realized I now had just enough paint for one more try. I just got that done. No more paint. I might have enough clear to do it if I shoot one coat. The next can won’t be here for 3 days. My truck is sitting in my driveway with no handles for the second night. Damn. Sometimes I hate painting.
0D648344-27EE-4B4D-AD10-A3A9E5E86E55.jpeg AC435DA1-3E3F-4A3F-A084-5F8775108985.jpeg 7FDC462E-A782-40F1-A5D6-BAA510C5B0F2.jpeg AE25481F-B534-4FBC-BA5E-C71FCD2EA47C.jpeg
That's the newer/revised formula of the U-Pol that I was trying to avoid. Since you seem to be having no issues with it, maybe I'll give it a whirl. Although, I did find a NOS can of the original stuff that I'm gonna use first.
A couple notes. On the passenger front, the lock had been punched in and I had put a piece of black plastic in there back during the aftermath of the break in. I hadn’t pulled the handle then, so this time I did a better job. I removed the lock cylinder from the rod inside the door where it was hanging, removed the rod so it’s disabled, and used the lock cylinder to hold a part of a plastic plug I modded to fit. It’s held in good now and I was able to paint it with the handle. It’s much better than before. The lock is attached with a clip and it pushes down on the plastic to hold it in place.
258186E0-16C9-4CB1-A08B-76EB8A26EB38.jpeg D6270A86-4C12-4095-A57D-7E4C81687E63.jpeg BC7DFB18-2907-477E-98E3-F7464DF3C768.jpeg B80D8DF4-A4BD-4432-BDAB-E36853581FA9.jpeg image.jpg
It’s working awesome for me.
A couple more pics. I also removed and re-glued the carpet on the front door panels because when I first did it, the glue didn't hold well. I used 3M Super 77 this time. You can see the darker color of the grills better on the fronts.
Smityinms
