****** peer pressure lol. Damn I almost gave up on that oil pan about 10 times. What a *****. I was so close to just saying the timing set and oil pump will have to stay. At one point, with the front diff dropped as far as it would go and the pan looking like it wasn't going to clear, I was sure I made a huge mistake and was going to have to pull the axles and remove the diff. Then I pried some more and there it was. Oil pan off. Must have taken 3 hours. Then I pulled the oil pump and timing chain but no matter what I tried, the lower timing gear wouldn't come off. I tried for over an hour, heating with a torch, driving a tool I made and pounding with an 8 lb sledge but no way. I read online that sometimes they have to be split in half. ridiculous. I stopped before I hurt it. I decided to just replace the chain and the cam gear and oil pump. I measured and tested and checked and the Cloyes chain works perfectly on the lower gear and is the exact same length and width as the OEM. I didn't get crazy with pictures, especially with the part where I was on my back under it (where I think I invented some new cuss words) but here ya go. First pic it starts. Then a shot of the radiator pulled and some of the butterflies I killed. Next is a shot of the front with radiator, intercooler, and A/C condenser removed. That was fun but I had no idea what was coming. A few more bugs, then a shot of what I used to pull the harmonic balancer. I know I shouldn't use the word, but I used a Chrysler balancer puller and modified the old crank bolt to use for it to push against. Easy breezy. The puller hooked on the center spokes of the balancer perfectly. I read this online somewhere.
