D’oh! Sorry Mark, just saw this. I guess from
One end to the other , they are maybe 8”..? I did get the 145°boot. Seem shorter than that, but possibly.
That’s ok, like I said I’m buying the same ones so I can swap them out individually as needed. I’m gonna try plugs to see if that’s the problem. I’m not holding my breath though. I have had a small intake leak according to Justin for a long time and always figured I’d need to R&R the blower. I have all new gaskets, they’ve been sitting on a shelf waiting for the dreaded time they’re needed. I guess if it needs to be done there probably isn’t a better time. I’m not working and The Machine isn’t torn down. Plus it’s a good time of the year- it’s not Winter. Sigh. Still sucks.
Sam Harris
Texas
Definitely sucks. Still hoping for the best / easiest solution. You still need a measurement.?
Alright, cool. So you got the 9070c, with the 145° “boot”.?
No,I got the same ones I have, they’re a no name custom set. They are the first ones I haven’t had any issues with. This way I can just replace the one or two that break when I remove them and use the rest as spares because I swear no matter that I use dielectric grease, there’s always one or two that pull apart because the part that snaps on the plug doesn’t wanna come off so it stays on the plug.
https://www.ebay.com/itm/351925993115
89Suburban
Bull in the china shop
SE PA
Check those plugs Mark can’t hurt. Any kind of buildup they start to misfire in my experience. These trucks are real sensitive to that.
Yeah, that’s pretty much my last thing to check. So I looked in my records to see when the last time I changed the plugs. It said 2/9/20 at 169,150 miles I put in Rutheniums. That brought back memories of that failed experiment. And thank god for this build thread, because I was able to go back and read up on what was going on. The Beast hated those plugs, misfires like crazy so bad it would barely run. That was 14 months ago, and I ended up installing the same plugs that have worked great since installing the blower but don't last long- NGK TR6 copper. I'm going to install a fresh set. I tried to go see what my mileage is right now but I cant read the mileage in the daytime since I installed 2-3 layers of blue film over the PRNDL display which I now need to remove at least one layer of. I'm feeling more like it might be the same issue again- it likes the cheap copper plugs but they don't last long. Come to think of it, for the last couple months it's been hard to start at times, kinda runs a bit rough until I give it some throttle for a sec and then it's fine. So I'm feeling more and more like that might be it. It's raining for a couple days but I'll swap them in soon. Oh crap, I'll have to wait for the new wires. Oh well, no hurry. It still seems to run OK just throws the code. And I don't drive much anyway right now. Here's a link to where I changed them last time. Rutheniums were swapped back to TR6's.
https://www.tahoeyukonforum.com/thr...ali-build-thread-aka-the-beast.83457/page-263
Got the plugs and wires in, plus it’s time for an oil change.
CoyotesRUS
