Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
ivin74
05 NBS Nali
Htown, Texas
Today I also wired in a new connector for the steering position sensor. I have a DTC C0455 symptom 0, front steering position circuit and according to alldata this will also disable traction control and stabilitrack which I am experiencing. There is a TSB stating they have a problem with corrosion in the connector and before changing the sensor, replace the connector. It didn't work. The Tech 2 shows a position of -232 degrees and it doesn't change when I turn the wheel. I followed the diagnostic steps at alldata and it looks like the sensor itself is bad which is a bummer because I need to pull the steering column to change it. Another project. Sensor ordered.
@Rocket Man
Did you have to program the new sensor? I replaced mine and I'm still getting the C0455?
I used the oem part from GM
@Rocket Man
No, there’s no programming that you can do iirc. I was able to look at the data on the Tech2 and verify it was working though. Do you have a Tech2? You might have corrosion in the connector like the TSB talks about. You might want to replace it.
ivin74
05 NBS Nali
Htown, Texas
I already replaced the sensor, I cleared the code with the tech2 and still getting the code. I see the live data but I don't know what that data means.
It should show the position of the steering wheel in degrees, with zero degrees at straight ahead iirc.
I’ll hookup my Tech2 later and see what the data says. It seems to me like it reads 0 degrees at straight ahead and negative degrees when you turn to the left and positive degrees when you turn to the right.
ivin74
05 NBS Nali
Htown, Texas
I’ll hookup my Tech2 later and see what the data says. ./QUOTE]
I know this is your build thread and don't wanna get off subject.
The data from the beast would help me alot, I'm thinking I have the steering wheel off center. You can PM the screen shots of your live data and I'll will compare them to mine. Thanks Mark
Mrfirewolf1000
