Roof Antenna wing delete possible?
97on22s
On a yukon denali is there a way to delete the antenna wing?
Also while im up there i was thinking about removing the roof rack?
This is all mainly to fit the truck in the garage.
Thanks
Ryan
timjohnson22
GEORGIA
If you delete the antenna wing you will lose onstar and XM. If you remove the roof rack you have to plug the holes so it does not get wet inside when it rains. Alot of car jackers break it off so we can't track our trucks with onstar.
97on22s
you cant re route it any place else? is there a way to block off the whole or anything?
mtarlton
I am with you guys. I am about to take that POS Onstar apart and figure out what I need to remove it permanently. I did the roof rack delete and the radio antenna delete, but have this friggin' Onstar walkie talkie antenna sticking up. Like a super model with gaped front teeth.
Regency
It's obviously possible just be ready to fork up though if you want to retain onstar/xm and fm/am I believe
felixgun
Lafayette, LA
what'd you do with the holes when you removed the roof rack?
edgaranah1
Corona California
I kinda like the antenna. but I seen them without and they look CLEAN.
Sent from my iPhone 4g using Tapatalk
Harald1959
