GranPrix
- Joined
- Sep 10, 2017
- Posts
- 703
- Reaction score
- 477
Did it work?
Haven't done it yet
Did it work?
don't do that on newer cars the capacitors might reverse current and damage items in the systemHaven't done it yet
( it only happens under certain conditions, i.e if a reverse current protection diode is broken)
just hook up an low power 12v bulb to discharge it with the battery disconnected..
did you disconnect the battery before working on it?
I have a 2019 and touching the terminals together is what it took to clear up my check engine light and rough running. Worked Great!don't do that on newer cars the capacitors might reverse current and damage items in the system
replaced my air filter no heavy shuttering so far, it was starting to get really bad almost impossible to drive (as it was continuous at low speeds yesterday) i drove it to day Zero issues even without waiting from going from reverse to driveI haven't had a chance to do anything to it but I drove it on Wednesday and it was way better. I had forgotten about it since it wasn't even acting up. I'll see on again Tuesday how it drives.
