Rough idle part 3 with a Vengeance
Hahaha holy shit...how did the rear brakes go from not even applying any pressure at all, causing you to stop in the middle of intersections to wearing out the pads in no time at all? You’re so full of ******** it’s unbelievable. :ban2::ban:
B
BG1988
HERE IS the time line... sorry if you got mixed up on it
bought
Stopping issue, longer stops then expected stopping, stopping in middle of street (i.e light goes stale green, yellow then red)
MY CITY SPEEDS ARE 45 to 60MPH Typical with the most common being 45 or 50mph
all 4 wheels locked up (with full momentary power loss Engine STILL RUNNING
that is when the issue started getting worse.. after 30 miles of the full momentary power loss
Rear passenger side started dragging...or (squealing) (when there is noise there is friction making said noise)
Currently Grinding sound at 'low speed' slow downs. that started with in the last 200 miles. when brake is applied and squealing is worse on rear passenger side while not pressed..
Fuel consumption has increased in the city see my fuelly log
B
BG1988
Brent, you need a brake job
yes the issue does exist
abnormal fuelly log (should be smoother between the city and highway ) as i always try to fill up before doing a highway
Per the june and july fill ups
wjburken
Eastern Iowa
Let’s see if I got it:
A vehicle was bought that had a mistake on the title in regards to the mileage. The dealership isn’t helping but there is something called a surety bond that gives leverage over the dealership. On top of that, the rear brakes don’t work/never worked and it takes too long to stop sometimes and there is metal to metal contact on the rotors but it’s usually not an issue because of the use of regenerative braking due to it being a hybrid. The current issue appears to be related to an unknown fuel consumption issue.
If I missed any of the major points, I’m sorry. But I feel like we need Barbara Billingsly to reprise her role in airplane so she can translate jive-talk for us.
RustedHoe04
