Well here we all are,
I wanted to pick the minds of some experts on my what I’m thinking is a front differential issue.
So I’ve rebuilt the entire front end on my Yukon since purchase. Steering,
suspension all brand new.
When engaging 4WD I get what feels like a big amount of drag. Every other vehicle I own is either 4WD or AWD solid Axel and IFS none of the others feel this way.
So not only do I have a dragging feeling when engaged in 4WD I’m getting a almost whir maybe you could call it a growl as I increase speed but only with 4WD engaged.
I also have a continuous *click or *tap that sounds very similar to a cv Axel. I initially
Thought maybe it was suspension angles, or alignment or steering issues and I was throwing axels out but I’ve since fixed/diagnosed all other related issues.
When I first got the the Yukon I drained and filled the front diff, and then I also check the level in the transfer case. t-case was fine on level. Front diff was low but it was to be expected. The PO had mentioned a front diff leak and hadn’t been using the 4WD except in emergencies as he had a fear of bombing the diff.
I replaced the front Axel seal reassembled everything and drained and filled the front diff.
Looking for some opinions maybe even some direction, I’m probably going to drain the front diff and see about metal shavings. Other than that I am not an expert in the field of differentials. I mean I’d give a rebuild a go …. But it’d be a first hahaha
