Well I got the rockers in.....pain in the ***.
The bad part of install is the entire ac compressor and power steering bracket as well as the alternator have to be loosened and moved a bit in order to get the cover over the now taller rockers. Also no instructions of any kind, like I needed them.
The way the locks work almost caused me a disaster as one came real loose at 5 k rpm and chewed up the valve tip a little, forgot to take a pic Not sure if it was my fault since that one was the sticky lifter I had that finally cleared. Any how I tore all down again and re-tightened, after setting zero lash with the engine running this time to ensure the lifters were actually pumped up. Seems to be ok now.......like will tell.
Pic of having to move bracket.
[/IMG]
Rest of them showing clearance.....I did NOT enlarge the holes in the head.
[/IMG]
[/IMG]
[/IMG]
Notice where the can of seafoam had dissolved lots of crap as I was trying to free a stuck lifter.
[/IMG]
[/IMG]
Good part is it pulls hard at 3500 all the way to 5300 shift point and never falls off like before.
I think the stock rockers were my bottleneck for all my other mods, because I swear with the cumulative mods it made a ~30 hp peak power difference.
Can't wait to dyno it and see the real numbers.
[/IMG]
