Scratched cluster plastic 2015
07denaliyuk
SE Michigan
Anyone know if this plastic lens can be easily replaced? My guess is a detailed used an aggressive cleaner and left it foggy.
I’ve tried simple green and tested toothpaste but no luck. In
the area Near the zero rpm.
I don’t want to use plastic polish until I know it can be replaced, in case it turns cloudy.
dbbd1
I've used plastic polish before on gauge panels with no ill effects.
cmatt
Yes, it can be replaced easily. There’s tabs around the perimeter that hold it onto the cluster assembly. I’ve got an extra to sell if you need it. PM me for details.
dbbd1
I’ve tried simple green and tested toothpaste but no luck. InView attachment 187548 the area Near the zero rpm.
Is yours an '07? You did post in the 15+ section.
RED TAHOE LS
Rossville, Georgia USA
James, if you use Mirror Glaze liquid and a headlamp restore sponge on a mandrel in your cordless drill I believe you would be surprised. I believe the sponge I have (smaller than a tennis ball) came in a Mother's headlamp kit.:2cents:
David g..........:)
07denaliyuk
SE Michigan
Thanks all! I will try those suggestions tonight and post the results.
It’s a 2015, I need to update my username.
ScottyBoy
Shreveport, La
Hand polish it with some Megiuar's M105 and some M205 polishes. I've seen far worse damage that was able to be polished out on a cluster lense.
Jongrreat
