Seafoam??
BOSS
The People's A D M I N
Dallas
Looking for a vacuum line. A little help would be great. I have an 02 NBS. No ones responding in my forum.
There's a bunch of threads on this topic, iir I posted in some of the good ones...take a min to search my posts on sea foam for more info....I actually fixed a multi cylinder misfire code with sf. I'm a believer now
B
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Seafoam is definitely not snake oil. I had a neighbor that bought a Nissan Altima 4-cylinder that had a CEL for over a year before he decided to fix anything on the car. He knew nothing about cars. We decided to start with a tune up. During the tune up we did seafoam with 1/3 oil, 1/3 gas, and 1/3 brake booster vacuum line. Man did that car smoke. It also helped reveal exhaust leaks. I made him go drive around to give the seafoam in the oil a chance to do its thing before doing an oil change and changing his plugs. When he came back the CEL was gone. We finished the tune up right after. To this day the CEL hasn't come back and the car still runs good. Made me a believer.
BOSS
Dallas
how long should it stay in the crankcase for? I know on the can it says just until the oil gets dirty.. are we talking a couple of hours here?
Basiclly if you follow the board land scriptures, it's generally thought good practice on a high mileage engine to gradually do a SF cleaning. I have never heard of any major issues to support that but it seems pragmatic in theory anyway. The supposed reason for using Dino oil during cleanings is that it wont compete for the metallic surfaces as much as a synthetic ....something like that. Again, lots of good threads here so take a minute to search around.
Here's what I did when I bought my Tahoe at 90k miles ...something like this if I recall:
-Dino oil change + 1/3 can SF
-Drove 500 miles
-Dino oil change + 1/2 can SF
-Drove 1000 miles
-Dino oil change + 1 can SF subst for 1/2qt of oil
-Drove 500 miles
-Kerosene flush
-Switched to Royal Purple
Feel free to correct me here fellas.
B
BOSS
Dallas
I did something similar on the intake, eased into it and probably did it 2 or 3 times....killing the engine each time, letting it sit for a few minutes, then drive for 50 miles or so...repeat. Then change the plugs out bc there's a good chance they're fouled ...so moral is wait for a plug change interval.
Tahoe_96
If I run seafoam through my intake will I need to change oil ....or is there even a possibility that it will get past the piston rings
kaoticlife
Port St Lucie, Florida
shouldnt get past the rings and if it was too then you would have more problems than seafoam could fix.
I did sea foam in mine just recently with 280k on the odometer and it made a big difference in idle, made it purr if you will. now wish it would have magically fixed my random egr code. I cleaned egr and still get the code every other start up.
Tahoe_96
thats what I was thinking but figured I would ask ppl that know more than I do on the subject.... after cleaning my throttle body last night I got the chance to see all the carbon build up under the plenum...so think ima spray it in through the throttle body rather than the vacuum line
HDRock1
Flint,Mi
Seafoam is a good product, seafoam in the tank, seafoam in the brake buster vacuum line,seafoam in spray form, inject into throttle body, all have instructions on the can.
I personally have never put it in the oil
CrazyCanexan7897
