bottomline2000
No sorry you no win nothing, I mentioned low fluid in post #4.
Dammit man, thought I had one bro cred or something lol. Cool your problem is fixed. I'm leaking coolant from somewhere too and can't find it. May have to do a dye test or something. Oil is clear and I suspect my resevoir is giving up the goods since the radiator is new.
as far as burping I take the radiator cap off and run the engine till up to operating temperature. The air will circulate once the thermostat opens and make its way to where the cap is and will literally burp and water level will drop. I keep adding fluid till the level stabilizes and then turn off the engine, replace radiator cap and top off reservoir. Worked in my car, but the NBS trucks don't have radiator caps so I just trust it does it on its own through the reservoir.
