SES light w/ code help
S
sgtmac
So I replaced the PCV and gas cap, SES still on. I can't hear any obvious sucking sounds under the hood, although, when I blip the throttle by hand I get a massive sucking sound, then she rev's up.
So what should I check next? I was hoping for an "ah-ha" but nothing yet.
Idle seems fine, at least no worse than when I got it 6 weeks ago. Ditto the gas mileage. Acceleration may be off, but if it is, it's marginal.
Thanks
S
sgtmac
I seem to remember being able to spray carb cleaner around suspect areas to find a leak on my old cars. I assume that trick won't work on fuel injection?
---------- Post added at 05:32 PM ---------- Previous post was at 04:02 PM ----------
Having a hard time tracing the lines, I can't tell but it sounds like the there may be a leak on the top and back of the motor. Does that sound like anything to anyone?
So click on the "pic" and it will open the video in a new window on Photobucket. The sound sucks, sounds nothing like my motor, way more wind noise but maybe it will help?
Thanks
_Dylan_
STAY FROSTY
yes you can still do the carb cleaner trick to find a vacuum leak
S
sgtmac
Does anyone have a vacuum line schematic? I could also you some ideas where to look next, usual suspects etc.
Thanks
S
sgtmac
Thank you sir!
Can you tell me what the name of this part is? I can't seem to figure it out.
Is it a dealer only part?
Thanks
BurbyRST
