Severe driver side tire wear?
Leonidas
What's Good TYF!!!!
North Carolina
washing the kon the other day and noticed my tire is severely worn on the inside closest to the wheel well. I'm wondering if I have a bent tie rod or something. Anyone else have or had this problem? I rotate my tires like they should be. Any help would be appreciated before I go snooping around under there.
Modded
That Guy
Camber is probably off if that is the only type of abnormal wear showing.
Get an alignment.
savila1021
I have the same thing on both fronts :/ feels like crap when I run through it. It's like one section up other down n so forth. But can't feel a thing when driving.
2007tahoe
Yea mine seems to cup the outside of the front tires, not bad but more than it should be. I have the correct psi, rotated every 6000, and about 25,000 miles on a set of firestone alenza hl. I did the alignment about 2 yrs ago myself when I worked at the shop so I know it was spot on. I guess I will have to go spent the money now and get it checked because the tires are way to expensive for them not to wearing even.
Tenn2033
