shackle flip
S
setty7
post some pics, so does anyone have a complete kit I can get by chance? Im the one to forget the most importan part. When you say cut the rivets of the stock shackle hanger what are you refering to?
AtomicHoe094
Atomichoe094
cleveland, OH
cutting the rivets out.. youll see once you look under your truck by the hangers and shackles. thats how everything was installed by the factory. youll have to cut those out or drill them out, the replace with new hangers/shackles using nuts and bolts..
BigDaddy13440
Rome, NY
I cut the rivets off my rear leafs, and slipped 3 extra leaves in between the stock leaves to lift the rear about 2 1/2". I'd used a metal cutoff saw to cut the leaves to length, looks like they were done at the factory. Bolted everything back together using a grade 8 1/2" bolt and Nylock nut (after opening the 7/16" holes up a bit), didn't have to mess with the pinion angle by using shims, either. Used longer u-bolts, and cut the excess thread off with my sawzall.
Noticeably more stability when going through turns (as the springs ARE stiffer), and I can carry a LOT more weight in the back. Have put over 1800lbs in the back, and not bottomed out. Yes, it rides like a truck, not a car, but I'm always carrying supplies and tools anyway.
Drumrunner
West Palm Beach
All you have to do is make a + on the rivet head with a cut off wheel then hit it with a air chisel. Rivets will push right through the frame. Quite easy but really noisey. Ear protection recomended.
S
setty7
thanks guys, seems a bit difficult for me to do? :hands: how much would a shackle flip install run?
AtomicHoe094
Atomichoe094
cleveland, OH
well do you own a drill, cutoff wheel, air chisel, and an air compressor?? if you do, then im pretty confident you can do it. But dont blame me on anything if you screw up
S
setty7
haha ^ no but i got someone that does! the only thing im worried about is the driveshaft angle and all
bowtiefreak
No Quarter
Near Philly
Driveshaft angle are a pain in the ass to figure out to a rookie, wanna know how I know that?
I just happen to have a few different degree shims if you need some. A standard driveshaft needs to have the front and rear U joints phased meaning the same angles. a CV shaft is different but I doubt you are running one
S
setty7
idt I am, would I be better off with a 3" block and 2" aal?
Silverspoon1217
