shakey 96 chevy tahoe
hyteck9
Columbus Ohio
Hello there.
I took it to the Dealer, They OK'd the Drive shaft, U-joints, etc...
I don't think they looked at the transfer case.
Anyway.. a bit more info...
The truck only does it when it has a load heavier than myself.
4 people
2 people plus heavy boxes
a trailer
etc..
This makes me think it is suspension related, but that all checked out too?
gpracer1
Phoenix
Next time you are cruising at a constant speed and you give it some throttle and it shudders, slightly press the brake pedal enough to make the brake lights turn on while holding speed and see if it goes away.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If only happening when loaded and your are getting clunking in first or second you could torque converter problems as the cause and should probably draw your attention to the slip yoke in the transfer case. The bump clunk issue they have had It has often be resolved by changing out the transfer case fluid for a new type but gm in 2001 had in development a new nickle plated slip yoke to solve the problem. If you like have the dealer inspect you current one to see if that where the problem alternately lies. The new ones sell for about $200 at dealers.
96GMCYukonGT
Mine does this too but not bad and I changed upper and lower ball joints on one side and its not as bad gonna change the other side next week Same year everything
B
big boy toy chevy
Sunlitcomet I wondered about the tires but b4 the u joint change the truck was as quiet as a mouse it started right after I had them changed no mounts are cracked as far as I can tell...I did notice the drive shaft looks like it had been put in a vice....Im wondering if I should just replace the rear shaft and go for there?
foreverfalcon40
Seems transmission related...have the valve bodies checked...even the torque converter. Have a tranny shop hook up a computer to it and go for a length drive.
MAKE SURE you leave them a tank of gas!
B
big boy toy chevy
I took the truck to a mechanic ......and he put it on the car lift and had someone give the truck a lil gas and showed me the low rumbling noise was coming from the front differential................Fu%k!!!
Donnie Yukonie
Yates Caretaker
thats wierd i had the same problem an mine was the torque converter it would shake stupid bad , an when it got hot it would clunk into gear an id have shift shock so bad id have to restart the truck from all the gas going from one end of the gas tank to the other.... ok that last part might have just a little bit of ******** behind it :)
