Shark fin for roof antenna
Ron C
Los Alamos, NM
Hello all,
I used a shark fin antenna, in the same color (white) as my Tahoe, but the sun up here turn them yellow in no time.
Does anyone know of one (shark fin) in the same finish as the luggage rack, outside door handles etc?
thanks,
Ron
Ilikemtb999
Denver
Are we talking oem antennas or aftermarket?
There’s low temp powder coating for plastics. Might be an option that’ll last.
Ron C
Ron C
Los Alamos, NM
well the sun/UV beats on it pretty good, and the luggage rack I put on seems to hold up pretty good.
well, either would work I guess. The internals are typically slid/screwed/glued in, so it would be easy to replace with anything "shark fin" So something ABS, with a matte outside would work.
Ilikemtb999
Denver
sure.. actually whatever would work, and is the right material, it's technically only a cover
Can you just not read? I asked IF you were using an aftermarket or an oem antenna. I THEN suggested a new coating option on whatever you’re ruining.
I would find it hard to believe that an oem one that’s painted would fade which made me think you’re using junk aftermarket ones. Automotive paint does not fade in the sun at least not that quick.
Ron C
Ron C
Los Alamos, NM
I saw: "Are we talking oem antennas or aftermarket?" and "sooooo aftermarket antenna?"
I think I can read, and what is written above, is what I read. Maybe you could try to write in, unambiguous, grammatically correct, and complete sentences.
Ron
Ilikemtb999
Denver
I asked you if you’re using aftermarket or oem antennas that are fading. You didn’t answer. It’s hard to help someone that can’t give you all of the information.
I find it incredibly hard to believe an oem paint is fading that bad in the sun, thus I had to infer that you’re speaking about aftermarket products. Maybe that’s wrong but without you saying one way or the other all I can do is assume.
PPV12HOE
NC
Ron I was browsing through Wish last night and came across a few different shark fins on there... I can't attest to the quality but they were cheap... only downside is the month long wait for the shipping after you buy them...
Ebay Mike
Detroit MI
Ron,
On my Tahoe I used the OEM Flat Black one and it works perfectly and has not faded at all. I can look for the part number if you like?
Mike--Hamilton Chevy
pugnaxx
