shes eating oil
SunlitComet
OBS Jedi-Do Good
unknown at this time.
then you have got to be leaking out somewhere maybe burning off as well externally. i take it your coolant is still a nice orange color and your plugs are clean without being oil fouled or covered in black gunk?
C
Chezoom
ill check into it, the previous owned did the head gaskets cause she had blown one. the coolant isn't in the greatest shape and leaks so I need a new water pump too.
C
Chezoom
wasn't entirely sure where it was coming from, but its been replaced and doesn't leak any more.I put a new temp sensor in it but it still reads off I believe
ezdaar
Chat Troll
Redneck central, Aka Houston
Have engine running, remove oil fill cap. Which way is the air moving?
Is it sucking air in or blowing air out..
Place sheet of paper over fill hole to easily determine the direction.
2014 Tahoe LTZ
