Shock & Strut information NEEDED!!! HELP
TheAutumnWind
I am going back and forth. I have ready some threads where guys say the 5100 is too stiff, and others say the 4600's are. May not lower after all whats best for bilstein series 5100 or 4600?
The ONLY difference between 4600's and 5100s is length, adjustability (in the front), and the chrome finish.
Internally they are exactly the same shock, and provide the same ride.
5100's @ their top lift setting will preload the front springs, and this might make the front end feel a bit stiffer.
Highly recommend bilstein shocks.
lamerem
lamerem
Yes I agree Bilsteins are the best choice. So if I am not going to level or lift the vehicle then the 4600 would be the way to go?
Pimpin Frog
CA
After countless hours, days and even months on forums after my air ride went out I went with the Bilstein 5100's. I have a bit of a frankentstein setup in regards to how I did it though. I left all of the stock (airride) springs and hardware and just today replaced my rear coils with z71's. Plain and simple, you CAN NOT go wrong with Bilsteins...
5100 more truck like, some say "jarring"
4600 closer to stock
Both are GREAT.
lamerem
lamerem
Since it's my wife's daily driver I may go 4600 just so she doesn't complain.
jetmech
It's weird to me how the dealer seams to be pricing out the normal shock according to my vin number though. I would think they would see it was Premium Smooth Ride, right? Some folks have said if the truck was equipped with Nivomat from the factory and then replaced with regular then it would sag in the rear from the softer springs. However, mine doesn't have any sag. This is so frustrating. I may try to call Chevrolet tech support this afternoon to see if I can pick their brain.
My wife's 2011 Tahoe has the ZW7 RPO code but "standard" blue rear shocks. I'm not sure what the Premium Smooth Ride option is supposed to accomplish if they use standard parts.
Murder n Mayhem
ZW7 is the premium smooth ride option, which means you're truck was originally equipped with the Nivomat rear shocks. They may have been replaced at some point with standard shocks. Some say the rear springs on the ZW7 trucks were softer since the shock incorporated some kind of automatic (non-air) load leveling feature, but I'm not certain on the softer spring/non-softer spring deal.
The Premium Smooth Ride (zw7) is a rear Nivomat & front regular shocks. The Nivomat rear are load bearing self leveling shocks & fully self contained (& stupid expensive). The stock coil springs are lesser tension & softer because they share the weight/work with the Nivomat shocks.
Parts I just used today converting from OEM Premium Smoothride system (will work as conversion on all OEM suspension systems for @ least years 2001-2006, some systems will require a resistor so dashboard warning light doesn't stay on)
Bilstein 5100 series Rear Shock Part #24-187237
Bilstein 5100 series Front Shock Part #24-186643
Bilstein Coil Springs Part # 199021 (also known as #15711646)
(I used 5100 series because they give room for lift which I plan on doing later but you can use the 4600 series. Spoke to Bilstein & they told me they were same shock, the 5100s just allow for 1" lift in front & 2.5" lift in rear & were different colors).
Today I replaced my 2003 Chevy Tahoe's 4 OEM shocks & springs. I put on the new shocks first but not the springs so I could see how it went without putting in the stiffer springs. The rear end sat lower, felt like it was loaded down or had load on the hitch. The right & left rear side moved around a lot more independently of each other & bounced much easier & longer.
I then went home & put the stiffer springs in. The truck rides like new. I was afraid I would lose some of the smoothness but hadn't. The Tahoe is more responsive, rides smooth & the new set up leveled out the truck perfectly (although I prefer the raked stance).
Stores like Autozone, napa etc wanted over $125 for each shock but I got them for less than half that by going to products site & finding local distributor & parts were ordered & available for pick up in 24 hours.
I (average joe driveway mechanic) did the whole conversion. It took about 2 hours in my driveway with limited tools & no spring compressor needed.
I researched this for over month on forums, sites, at performance shops, product manufacturers etc. I firmly believe this is the easiest way to convert from the overrated stock OEM system to one that rides very closely to OEM, fully functional & are a superior quality product. Once the new rear springs are installed you can put on any shocks that fit the z71 package for your year. Bilsteins best bang for your buck @ $444 for 4 shocks & 2 springs.
Hope this helps anyone considering converting your Chevy SUV or truck.
Murder n Mayhem
The Premium Smmoth Ride (zw7) is a rear Nivomat & front regular shocks. The Nivomat rear are load bearing self leveling shocks & fully self contained (& stupid expensive). The stock coil springs are lesser tension & softer because they share the weight/work with the Nivomat shocks.
Murder n Mayhem
ccapehartusarmyINF.(ret)
Gilbert AZ
now i got a 4x4 again im goin with rancho RS9000's i had RS5000's on 2008 ranger fx4 and they could take a beating
but they are a stiff ride
but they last forever
jvelderman
