zach2011
Platinum Member
- Joined
- May 18, 2009
- Posts
- 1,640
- Reaction score
- 4
You might've saw my thread from a little while ago, about my battery being completely drained after leaving the Tahoe running for about 10 minutes (doing the tire pressure reset procedure).
Well, I've had more problems. Twice this weekend, I've tried starting it and for the first 2 or 3 attempts, it just clicks like the battery's dead. But if I give it a few seconds and try again, it starts up, but tries harder to than normal.
And last night, I tried remote starting it, and no matter what I did with the key fob, the Tahoe wouldn't do anything. It wouldn't even lock/unlock, so I had to do that manually. When I opened the door, no interior lights came on, and I got the usual failure to start until I tried a few more times.
I'm past the 36,000 mile mark for the warranty, so I don't know if the dealer would fix this without charging a lot.
What do you guys suggest I do...replace it and add a second? And what batteries have worked well for you?
Thanks, any help is appreciated.
