Show off your 2015+ leveled Tahoes and Yukons!
SteveMansur
Bilstien 5100 leveling shocks on all 4 corners and a 0.75inch daystar rear coil spacer. 285/65/20 BFG AT KO2 tires on 20inch denali rims.
SteveMansur
Looks great! No rub with 34.5” tires?
Thanks! Only rubs on aboslute full lock if you are in a tight parking lot. On the road it doesn't run at all, and off road only in extreme articulation, nothing major though.
SteveMansur
How much did it raise the front end with the 5100's?
Not much, Bilstien says it should raise the front by about 1.75inches. After 20,000km on them I feel they sagged down slightly. It still has the tipped forward factory look (just lessened slightly). I previously had a rough country 2inch spacer on the front and fealt it was significantly higher up, but if need be you just get a suspension max kit with strut disks to fine tune how much front lift you want (might do that soon).
oceanhut
Just picked the Tahoe up last week. 2018 LT. Painted the front grille, emblems, took lettering off, 2.5” pro-comp level, 18” Fuel Anza with 275/70 Nitto Terra Grappler
ttusomeone
Just picked it up from the shop yesterday night and this is the best pic I could get. It's been raining all day today and is supposed to rain for the next several days, so as soon as it stops and I can clean it up I'll get some better ones.
2017 Tahoe Z71 with a 6" BDS lift on 20x10 -12 Fuel Mavericks with 295/60R20 Toyo AT2. Added the AMP Research steps and kept a 1/2 spacer on the front to keep it level. No tire rub whatsoever with just some minor trimming of the inner front fender corner. I rolled the rear of the front fenders in with the tires I previously had and there's still plenty of clearance. Loving the way it looks. I do notice that I need to get the lane departure assist adjusted though.
I'm also looking to get a custom light bar built for the front so I can add a 20" LED Light bar.
AZCreeker
Can you comment how is the ride quality switching to 5100s on all 4 corners?
I have a 15 suburban with 56k miles and wondering if adding these (and raising the front just a bit, like 1") would improve the ride comfort over bad roads,potholes,snake lines,etc...
thanks for your feedback!
Derek Burner
