Meccanoble
I checked my gaps on spark plugs and was concerned about v4 causing issue this why I got it deleted. Still there...
Yes it has dod/afm cylinder deactivation....Does it have cylinder deactivation? Mine does, and I can always feel a light shudder at light load when in goes into V-4 mode.
Well after driving around for TWO hours around town, here is the result.
1st hour (approximately) no shudder.
Transmission temp was as high as 180 degrees (usually 160ish degrees starts shuddering) was happy....so happy I bought the Lubeguard trans additive, came home and poured it in....
Then I went for a spin.....
2nd hour decided to test in M5 mode to lock out any vibration from v4 mode.
1 shudder....then another shudder 20 mins later.
Tried tow/haul mode off and on with m5 and regular drive mode and as long as tow/haul is on No shudder at all.
So don't know what to think, but I'd say 80 percent better....but now I'm thinking tow/haul advances the timing a little, so if I got a tune(even a canned tune like Hypertech) I could cure this shudder a low rpms....who knows, the shudder could just be detonation from factory timing....
This really sounds like the lockup torque converter is slipping. Unless I'm mistaken, the lockup part of the torque converter is disabled in gears 1 and 2. It must be disabled in the tow/haul mode as well.
With a Tech2 you can see all of this, even how much the converter is slipping. My AFM was seamless, never felt or heard a thing when it turned on and off.
I am presuming that the computer disables the lock up feature of the torque converter in the tow haul mode.When you say "it must be disabled in tow/haul mode" are stating it is disabled in tow/haul mode? Or are you presuming it is disabled in tow/haul mode since I don't get the shudder in tow/haul mode?
