Smokeymance's Denali Build
FamilyTruckster
Awesome Dude McChainsaw
Detroit-ish, MI
Looks like you added one mini tiger power in the process...bad dood! Color me jealous, that friggin tvs1900.can't come soon enough! Lemme know your thoughts on the 8 rib as I'll be looking that direction once I bolt my blower on. Also, I thought the newer Maggie's came w the hd tensioner??? I was magnusons first case of broken tensioners back with the radix on my 6.0 SSS.... Was a nightmare, always had to keep a spare tensioner, belt and tools in my truck at all times... Roughly a 2 to 3 tensioner a month habbit... Got old fast, really hope I'm not stepping back into that situation... Anywho, Looking good and exciting, be sure to give me a ride when you finish up... Def need another motivator pull soon!
Smokymance
Smokymance
Boosted
MI
Will do...no mine didnt come w HD tensioner...
8 rib isnt necessary unless u get some crazy spin...number one thing i learned is to key that crank..key that crank...key that crank...my crank shaft has some scar marks from it spinning as well as my crank bolt came off super easy...
FamilyTruckster
Detroit-ish, MI
Same with the magna volt I believe.... Feel like I was their test dummy at my own (very expensive) expense for a long time... Call me stupid but Still want anothert though!
Smokymance
Smokymance
Boosted
MI
This is how i spent last week. Ended up purchasing the kit from here...16" wilwood 6 piston ....makes the stock rotors look baby...i need to get the rears now as they look way small...sorry for the pic overload
Also finally adjusted the rear panhard bar to center rear axle after the drop...installed last year but never really got to adjusting it
Fosscore
Sounds so good. I am glad you bought those damn Wilwoods!! I saw them as soon as he listed them but just couldn't pony up. Perfect for that supercharged beast to stop her down. :thumbsup:
Smokymance
Smokymance
Boosted
MI
Thanks guys. Yea she needs black and shorter lugs nuts. She deff needs them. U can tell I heat cycled those stick rotors a few times. Now I need to find some rears!!
bufaton
