Smoking Hot Rotors? What gives
treepete
Wisconsin
ok my whole post was just wiped, so now you get the abbreviated version.
I smelled something funny at the gas station this morning. check my front wheel while putting in air and it was hot between the spokes. whatever..
I got to work and checked it again, and it was totally SMOKING from behind the rotor. smelled like burning plastic or chemical smell that Im not used to smelling from ANY vehicle.:shocked: smoke everywhere.
I have a movie of the smoking, but I cannot attach it, for the file type is invalid.
so yeah. safe to drive home? or get it towed or what the heck is going on there?
thanks for reading this post and thanks for the warm welcome.:Handshake:
Pete
ravingmadman
Chief Knuckle Buster
Greater Seattle
Yeah, pull off wheel, remove the caliper bolts (you'll need a long-handled hex wrench), get the caliper off, remove the inner brake pad (it just clips in, use a screwdriver to pop it off), use a C-clamp to push the piston back into the caliper. If it moves freely (it will be slow), that's not your problem, check your wheel bearing by putting a couple lugs back on, and trying to wiggle the disc in all directions. Bearings are easy and cheap to do yourself. $150 in parts, and with the tools, only an hour to do each side. You don't have to pack them, or anytyhing, they just bolt off, bolt on. Easy. PM me for instructions? If there's enough interest, I'll post another how-to with some pictures.
treepete
treepete
Wisconsin
I was talking with Jiminy and he said the same about the piston being stuck. He thinks perhaps that the inner pad is being pressed onto the rotor, causing the heat, as well as the truck wanting to pull to the right. ( which I didnt mention, cause I thought it was due to the low air pressure.)
Ill have to get the hotrod out of the garage and pull the yukon in there and have a look.
AS SOON A JIMINY RETURNS MY AIR COMPRESSOR... ahh crap I gotta take the wheel off by hand??? dude.
lame.
thanks for the tips guys I will look at it and let you know what I find. all people seem to think hung caliper.
treepete
treepete
Wisconsin
yeah, hung up piston in the caliper. Good news is that they are 15.99 from autozone minus the core. Man, I seriously heat treated the pads and rotor on this little venture.
I wont be even slightly surprised if the rotor is warped.
thanks for your help, guys.
Pete
CHENTE
