Snow Driving
YukonandtheHOE
Awd and 4hi are the same thing, just awd's have no option for 2wd. Auto is when the truck monitor's wheel slippage and engages 4x4 when its needed
ever noticed how the gear selector
Can be easily be pushed into neutral? that is designed for driving on ice. In the event your wheels are locked up on ice, use the neutral bump to cut power to the wheels and lightly pump the breaks.
cardude2000
Pump brakes? I haven't heard that since the pre ABS days.
MTVP
Houghton Lake, MI.
Haha ,ABS does not always make you stop a shorter distance on ice or snow. But you can at least steer into what you're going to hit. Or caught a break and miss it.
Old school was why you were pumping the brakes to get some steering back.
All of which has nothing to do with AWD vs. 4WD. A thread seldom stays on point.
ISU-152
Driving in snow isnt hard. Just drive appropriately. That's it. If you are unsure of the conditions find a small side street and do a quick brake check to see what your stopping distance is. Our trucks wont have issues accelerating as long as you have the appropriate tires. 4x4 or 2x
Also err on the side of stopping for yellow lights first if it's safer. There's always that one last guy who will want to turn in front of you...just mind who's behind you. Also don't take corners too hard...the mid-high center of gravity will carry you sideways.
Bout all a Canadian can say ;)
Fosscore
^^This. Good info to follow, even for experienced drivers.
My mom was all about the brake pumping action in snow, heavy rain, dust storms....still sticks with me mostly to warn off the idiots coming up my tail on the race track known as I-95.
ISU-152
Actually I could add a couple more points. Keep your distance and concentrate on "reading" the play.
If you're driving in the right lane in the city expect more stops for people making right turns...thats usually why they are there. Same goes for the dreaded left lane turn with no turn lane
If the winter is really bad I'll take my tires down from 35-32 psi as well
YukonandtheHOE
This isn't a Snow and ice driving thread?:mexsmoke:
Epicshift23
