ISU-152
- Joined
- Aug 12, 2016
- Posts
- 1,061
- Reaction score
- 294
That's for ******....im sure there's a thread on thatLol Everyone know's you can't do sweet jumps with the abs fuse in![]()
Haha and im sure its not on point!That's for ******....im sure there's a thread on that
Awd and 4hi are the same thing, just awd's have no option for 2wd. Auto is when the truck monitor's wheel slippage and engages 4x4 when its needed
ever noticed how the gear selector
Can be easily be pushed into neutral? that is designed for driving on ice. In the event your wheels are locked up on ice, use the neutral bump to cut power to the wheels and lightly pump the breaks.
Ummmm.....I hope you're kidding. For those that are actually new to driving in ice please do the rest of us a favor and never drop the truck into neutral when it's slick out. I'm pretty sure that's not what neutral is for. ;-)
If it's so slick that being in gear causes you to slide you have a lot worse problems. However, you need to be bumping the gas and get the tires moving, then pray that you can actually steer your way through whatever may be happening. Pumping the brakes in neutral isn't going to stop you if it's that slick out, all you've done is take away any control you might have had when the tires stop sliding.
